Ga door naar hoofdinhoud
ASUS Q302L Trackpad Replacement
Wat je nodig hebt
  1. ASUS Q302L Trackpad Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Trackpad Replacement: stap 2, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement: stap 2, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement: stap 2, afbeelding 3 van 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Trackpad Replacement: stap 3, afbeelding 1 van 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Trackpad Replacement, Battery: stap 4, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Trackpad Replacement: stap 5, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement: stap 5, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Trackpad Replacement: stap 6, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement: stap 6, afbeelding 2 van 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Trackpad Replacement, Fan: stap 7, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement, Fan: stap 7, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  8. ASUS Q302L Trackpad Replacement: stap 8, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement: stap 8, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement: stap 8, afbeelding 3 van 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  9. ASUS Q302L Trackpad Replacement: stap 9, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement: stap 9, afbeelding 2 van 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  10. ASUS Q302L Trackpad Replacement, Motherboard: stap 10, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement, Motherboard: stap 10, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  11. ASUS Q302L Trackpad Replacement: stap 11, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement: stap 11, afbeelding 2 van 2
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  12. ASUS Q302L Trackpad Replacement: stap 12, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement: stap 12, afbeelding 2 van 2
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  13. ASUS Q302L Trackpad Replacement: stap 13, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement: stap 13, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement: stap 13, afbeelding 3 van 3
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  14. ASUS Q302L Trackpad Replacement: stap 14, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  15. ASUS Q302L Trackpad Replacement: stap 15, afbeelding 1 van 2 ASUS Q302L Trackpad Replacement: stap 15, afbeelding 2 van 2
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
  16. ASUS Q302L Trackpad Replacement, Trackpad: stap 16, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement, Trackpad: stap 16, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement, Trackpad: stap 16, afbeelding 3 van 3
    • Carefully disconnect the ribbon connector from the touchpad using an iFixit opening tool.
    • Slowly peel the grounding strap off of the touchpad.
    • Use a Phillips #0 screwdriver to remove the three 2 mm screws holding the touchpad.
  17. ASUS Q302L Trackpad Replacement: stap 17, afbeelding 1 van 3 ASUS Q302L Trackpad Replacement: stap 17, afbeelding 2 van 3 ASUS Q302L Trackpad Replacement: stap 17, afbeelding 3 van 3
    • Carefully lift and slide the touchpad towards the hinges using an iFixit opening tool.
    • Remove the touchpad.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 521
