Ga door naar hoofdinhoud
ASUS Q302L Hard Drive Replacement
Wat je nodig hebt
  1. ASUS Q302L Hard Drive Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Hard Drive Replacement: stap 2, afbeelding 1 van 3 ASUS Q302L Hard Drive Replacement: stap 2, afbeelding 2 van 3 ASUS Q302L Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Hard Drive Replacement, Battery: stap 4, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Hard Drive Replacement: stap 5, afbeelding 1 van 3 ASUS Q302L Hard Drive Replacement: stap 5, afbeelding 2 van 3 ASUS Q302L Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Hard Drive Replacement: stap 6, afbeelding 1 van 2 ASUS Q302L Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 2 ASUS Q302L Hard Drive Replacement, Hard Drive: stap 7, afbeelding 2 van 2
    • Unplug the hard drive from the connector.
    • Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
  8. ASUS Q302L Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver and remove the four 5mm screws on both sides connecting the Hard Drive to the mounting bracket.
    • Remove the Hard Drive from mounting bracket.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 1,552
