Ga door naar hoofdinhoud
ASUS Portable AiO PT2001 RAM Replacement
Wat je nodig hebt
  1. ASUS Portable AiO PT2001 RAM Replacement, Back Panel: stap 1, afbeelding 1 van 3 ASUS Portable AiO PT2001 RAM Replacement, Back Panel: stap 1, afbeelding 2 van 3 ASUS Portable AiO PT2001 RAM Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS Portable AiO PT2001 RAM Replacement: stap 2, afbeelding 1 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 2, afbeelding 2 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 2, afbeelding 3 van 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS Portable AiO PT2001 RAM Replacement: stap 3, afbeelding 1 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 3, afbeelding 2 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS Portable AiO PT2001 RAM Replacement, RAM: stap 4, afbeelding 1 van 2 ASUS Portable AiO PT2001 RAM Replacement, RAM: stap 4, afbeelding 2 van 2
    • Peel off the tape attaching the metal enclosure to the heat sink.
    • Lift the metal enclosure off of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS Portable AiO PT2001 RAM Replacement: stap 5, afbeelding 1 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 5, afbeelding 2 van 3 ASUS Portable AiO PT2001 RAM Replacement: stap 5, afbeelding 3 van 3
    • Pull the jaws of the white plastic frame apart. This will pop the front of the RAM up.
    • Gently lift the front edge of the RAM.
    • Pull the RAM out and up.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Elliot Kane
381 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G5, Livingston Spring 2018 Lid van Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 37
Altijd: 1,747
