Ga door naar hoofdinhoud
ASUS MeMo Pad FHD10 Battery Replacement
Wat je nodig hebt
    1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS MeMo Pad FHD10 Battery Replacement: stap 2, afbeelding 1 van 2 ASUS MeMo Pad FHD10 Battery Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      Vraag FixBot
      Voeg opmerking toe
    3. ASUS MeMo Pad FHD10 Battery Replacement: stap 3, afbeelding 1 van 2 ASUS MeMo Pad FHD10 Battery Replacement: stap 3, afbeelding 2 van 2
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      Vraag FixBot
      Voeg opmerking toe
    4. ASUS MeMo Pad FHD10 Battery Replacement: stap 4, afbeelding 1 van 3 ASUS MeMo Pad FHD10 Battery Replacement: stap 4, afbeelding 2 van 3 ASUS MeMo Pad FHD10 Battery Replacement: stap 4, afbeelding 3 van 3
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dmitry
391 Reputatie
3 handleidingen geschreven
USF Tampa, Team 9-5, Blackwell Winter 2015 Lid van USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Leden
10 handleidingen geschreven
1Gids Commentaar
Where i can get new battery for this tablet?
Night Knight - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 42
Altijd: 10,782
