Ga door naar hoofdinhoud
ASUS Eee PC 1018P Keyboard Replacement
Wat je nodig hebt
  1. ASUS Eee PC 1018P Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS Eee PC 1018P Keyboard Replacement: stap 2, afbeelding 1 van 2 ASUS Eee PC 1018P Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS Eee PC 1018P Keyboard Replacement: stap 3, afbeelding 1 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 3, afbeelding 2 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 3, afbeelding 3 van 3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS Eee PC 1018P Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the screws securing the bottom case to the keyboard.
    • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
    • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
    • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS Eee PC 1018P Keyboard Replacement: stap 5, afbeelding 1 van 2 ASUS Eee PC 1018P Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
    • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    Vraag FixBot
    Voeg opmerking toe
  6. ASUS Eee PC 1018P Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
    • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
    Vraag FixBot
    Voeg opmerking toe
  7. ASUS Eee PC 1018P Keyboard Replacement: stap 7, afbeelding 1 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 7, afbeelding 2 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the black ribbon cable from the motherboard.
    • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
    • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
    • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
    Vraag FixBot
    Voeg opmerking toe
  8. ASUS Eee PC 1018P Keyboard Replacement: stap 8, afbeelding 1 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 8, afbeelding 2 van 3 ASUS Eee PC 1018P Keyboard Replacement: stap 8, afbeelding 3 van 3
    • Remove the white ribbon cable from the motherboard.
    • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
    • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
    Vraag FixBot
    Voeg opmerking toe
  9. ASUS Eee PC 1018P Keyboard Replacement: stap 9, afbeelding 1 van 1
    • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael
43 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-13, Maness Winter 2012 Lid van Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 5,200
