Ga door naar hoofdinhoud
ASUS EEE PC701SD-WHI004X Keyboard Replacement
Wat je nodig hebt
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: stap 2, afbeelding 1 van 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: stap 2, afbeelding 2 van 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: stap 4, afbeelding 1 van 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: stap 4, afbeelding 2 van 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
mir
409 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G8, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G8
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 928
