Ga door naar hoofdinhoud
APS Tech 101629 SCSI Connections Replacement
Wat je nodig hebt
    1. APS Tech 101629 SCSI Connections Replacement, External Casing: stap 1, afbeelding 1 van 3 APS Tech 101629 SCSI Connections Replacement, External Casing: stap 1, afbeelding 2 van 3 APS Tech 101629 SCSI Connections Replacement, External Casing: stap 1, afbeelding 3 van 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. APS Tech 101629 SCSI Connections Replacement: stap 2, afbeelding 1 van 2 APS Tech 101629 SCSI Connections Replacement: stap 2, afbeelding 2 van 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. APS Tech 101629 SCSI Connections Replacement: stap 3, afbeelding 1 van 2 APS Tech 101629 SCSI Connections Replacement: stap 3, afbeelding 2 van 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Vraag FixBot
      Voeg opmerking toe
    4. APS Tech 101629 SCSI Connections Replacement: stap 4, afbeelding 1 van 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Vraag FixBot
      Voeg opmerking toe
    5. APS Tech 101629 SCSI Connections Replacement: stap 5, afbeelding 1 van 2 APS Tech 101629 SCSI Connections Replacement: stap 5, afbeelding 2 van 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Vraag FixBot
      Voeg opmerking toe
    1. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: stap 6, afbeelding 1 van 2 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: stap 6, afbeelding 2 van 2
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. APS Tech 101629 SCSI Connections Replacement: stap 7, afbeelding 1 van 2 APS Tech 101629 SCSI Connections Replacement: stap 7, afbeelding 2 van 2
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      Vraag FixBot
      Voeg opmerking toe
    1. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: stap 8, afbeelding 1 van 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: stap 8, afbeelding 2 van 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: stap 8, afbeelding 3 van 3
      • Remove the four Phillips #1 Screws from back panel.
      • Once the screws are removed, the two connections are easily removed from the body.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Patrick Meyer
83 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-60, Amido Spring 2011 Lid van Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 1,337
