Ga door naar hoofdinhoud
APS Tech 101629 Internal Drive Component Replacement
Wat je nodig hebt
    1. APS Tech 101629 Internal Drive Component Replacement, External Casing: stap 1, afbeelding 1 van 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: stap 1, afbeelding 2 van 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: stap 1, afbeelding 3 van 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. APS Tech 101629 Internal Drive Component Replacement: stap 2, afbeelding 1 van 2 APS Tech 101629 Internal Drive Component Replacement: stap 2, afbeelding 2 van 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. APS Tech 101629 Internal Drive Component Replacement: stap 3, afbeelding 1 van 2 APS Tech 101629 Internal Drive Component Replacement: stap 3, afbeelding 2 van 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Vraag FixBot
      Voeg opmerking toe
    4. APS Tech 101629 Internal Drive Component Replacement: stap 4, afbeelding 1 van 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Vraag FixBot
      Voeg opmerking toe
    5. APS Tech 101629 Internal Drive Component Replacement: stap 5, afbeelding 1 van 2 APS Tech 101629 Internal Drive Component Replacement: stap 5, afbeelding 2 van 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Vraag FixBot
      Voeg opmerking toe
    1. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: stap 6, afbeelding 1 van 2 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: stap 6, afbeelding 2 van 2
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. APS Tech 101629 Internal Drive Component Replacement: stap 7, afbeelding 1 van 2 APS Tech 101629 Internal Drive Component Replacement: stap 7, afbeelding 2 van 2
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alexis Weckel
140 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-60, Amido Spring 2011 Lid van Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 1,537
