Ga door naar hoofdinhoud
APEX TM785CH Microphone Replacement
Wat je nodig hebt
  1. APEX TM785CH Microphone Replacement, Back Casing: stap 1, afbeelding 1 van 2 APEX TM785CH Microphone Replacement, Back Casing: stap 1, afbeelding 2 van 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: stap 2, afbeelding 1 van 3 APEX TM785CH Microphone Replacement, Microphone: stap 2, afbeelding 2 van 3 APEX TM785CH Microphone Replacement, Microphone: stap 2, afbeelding 3 van 3
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: stap 3, afbeelding 1 van 1
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Conclusie
Brian Graschel
823 Reputatie
6 handleidingen geschreven
Baylor, Team 4-1, Williams Spring 2015 Lid van Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 189
