Ga door naar hoofdinhoud
APEX AP-GS918 Speakers Replacement
Wat je nodig hebt
  1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: stap 1, afbeelding 1 van 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: stap 1, afbeelding 2 van 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: stap 1, afbeelding 3 van 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    Vraag FixBot
    Voeg opmerking toe
  2. APEX AP-GS918 Speakers Replacement: stap 2, afbeelding 1 van 3 APEX AP-GS918 Speakers Replacement: stap 2, afbeelding 2 van 3 APEX AP-GS918 Speakers Replacement: stap 2, afbeelding 3 van 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    Vraag FixBot
    Voeg opmerking toe
  3. APEX AP-GS918 Speakers Replacement: stap 3, afbeelding 1 van 2 APEX AP-GS918 Speakers Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    Vraag FixBot
    Voeg opmerking toe
  4. APEX AP-GS918 Speakers Replacement, Speakers: stap 4, afbeelding 1 van 3 APEX AP-GS918 Speakers Replacement, Speakers: stap 4, afbeelding 2 van 3 APEX AP-GS918 Speakers Replacement, Speakers: stap 4, afbeelding 3 van 3
    • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
    • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
    • Start by peeling back the black electrical tape covering the motherboard components
    • You will also need to remove the black cloth tape covering the wire contact points.
    Vraag FixBot
    Voeg opmerking toe
  5. APEX AP-GS918 Speakers Replacement: stap 5, afbeelding 1 van 2 APEX AP-GS918 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Now that the contacts are exposed, you can desolder them.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Megan Lozicki
416 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-1, Leahy Winter 2015 Lid van USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 35
Altijd: 527
