Ga door naar hoofdinhoud
APEX AP-GS918 Camera Replacement
Wat je nodig hebt
    1. APEX AP-GS918 Camera Replacement, Power/Volume Button: stap 1, afbeelding 1 van 3 APEX AP-GS918 Camera Replacement, Power/Volume Button: stap 1, afbeelding 2 van 3 APEX AP-GS918 Camera Replacement, Power/Volume Button: stap 1, afbeelding 3 van 3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Vraag FixBot
      Voeg opmerking toe
    2. APEX AP-GS918 Camera Replacement: stap 2, afbeelding 1 van 3 APEX AP-GS918 Camera Replacement: stap 2, afbeelding 2 van 3 APEX AP-GS918 Camera Replacement: stap 2, afbeelding 3 van 3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Vraag FixBot
      Voeg opmerking toe
    3. APEX AP-GS918 Camera Replacement: stap 3, afbeelding 1 van 2 APEX AP-GS918 Camera Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    1. APEX AP-GS918 Camera Replacement, Camera: stap 4, afbeelding 1 van 3 APEX AP-GS918 Camera Replacement, Camera: stap 4, afbeelding 2 van 3 APEX AP-GS918 Camera Replacement, Camera: stap 4, afbeelding 3 van 3
      • Remove the black electrical tape covering the motherboard components along with the black cloth tape covering the camera itself.
      • Be careful when removing the black cloth tape from the camera on the top left corner of the tablet. The tape will likely stick and pull the camera with it.
      Vraag FixBot
      Voeg opmerking toe
    2. APEX AP-GS918 Camera Replacement: stap 5, afbeelding 1 van 3 APEX AP-GS918 Camera Replacement: stap 5, afbeelding 2 van 3 APEX AP-GS918 Camera Replacement: stap 5, afbeelding 3 van 3
      • Locate the white and gray connector that's holding the camera in place.
      • Use the black nylon spudger to eject the camera from its slot by gently lifting the gray clip vertically 90°.
      • Once ejected, you may easily remove the camera by pulling it from its slot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Megan Lozicki
416 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-1, Leahy Winter 2015 Lid van USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 596
