Ga door naar hoofdinhoud
APEX AP-GS918 Battery Replacement
Wat je nodig hebt
    1. APEX AP-GS918 Battery Replacement, Power/Volume Button: stap 1, afbeelding 1 van 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: stap 1, afbeelding 2 van 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: stap 1, afbeelding 3 van 3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Vraag FixBot
      Voeg opmerking toe
    2. APEX AP-GS918 Battery Replacement: stap 2, afbeelding 1 van 3 APEX AP-GS918 Battery Replacement: stap 2, afbeelding 2 van 3 APEX AP-GS918 Battery Replacement: stap 2, afbeelding 3 van 3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Vraag FixBot
      Voeg opmerking toe
    3. APEX AP-GS918 Battery Replacement: stap 3, afbeelding 1 van 2 APEX AP-GS918 Battery Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    1. APEX AP-GS918 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 APEX AP-GS918 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
      • Begin removing the black tape covering the motherboard inside the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. APEX AP-GS918 Battery Replacement: stap 5, afbeelding 1 van 1
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      Vraag FixBot
      Voeg opmerking toe
    3. APEX AP-GS918 Battery Replacement: stap 6, afbeelding 1 van 2 APEX AP-GS918 Battery Replacement: stap 6, afbeelding 2 van 2
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Megan Lozicki
416 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-1, Leahy Winter 2015 Lid van USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Leden
9 handleidingen geschreven
1Gids Commentaar
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 32
Altijd: 965
