Ga door naar hoofdinhoud
AKASO KingPad A90 WiFi Antenna Replacement
Wat je nodig hebt
  1. AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: stap 1, afbeelding 1 van 3 AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: stap 1, afbeelding 2 van 3 AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: stap 1, afbeelding 3 van 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 WiFi Antenna Replacement: stap 2, afbeelding 1 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 2, afbeelding 2 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 2, afbeelding 3 van 3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the the soldering points of the antenna on the motherboard.
    • Peel back the protective tape that covers the display ribbon cable so it isn't too close to the soldering points.
    • Solder hardens and cools quickly; you don’t need to wait to move on to the next step.
  3. AKASO KingPad A90 WiFi Antenna Replacement: stap 3, afbeelding 1 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 3, afbeelding 2 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 3, afbeelding 3 van 3
    • If you do not know how to solder, be careful and follow steps precisely because you could otherwise ruin the device.
    • With the new antenna locate the solder points.
    • Add solder to the solder points to allow soldering.
    • Place the antenna at each point and melt the solder point.
    • Place the antenna solder location into the melted solder blob and let it sit for about 2 seconds.
    • Repeat this step for each of the solder points.
  4. AKASO KingPad A90 WiFi Antenna Replacement: stap 4, afbeelding 1 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 4, afbeelding 2 van 3 AKASO KingPad A90 WiFi Antenna Replacement: stap 4, afbeelding 3 van 3
    • Replace the back cover with the new part in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Daniel Garcia
179 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 595
