Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will show you the tools and directions needed to carefully replace the joystick component on the 8Bitdo N30 Arcade Stick without damaging the Retro game controller. For this fix, you will be needing a Phillips #0 screwdriver and a flathead screwdriver to remove screws. Throughout this process, you will also need to take caution in regards to removing and organizing the pieces of the 8Bitdo N30 Joystick.
Wat je nodig hebt
For the new joystick, follow the steps in reverse order. Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
Één andere persoon heeft deze handleiding voltooid.
