Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the device over so that the bottom of the device is facing up.
Use a Phillips #0 screwdriver to remove all ten of the 3 mm screws on the back plate.
Remove the rubber slider from the device.
Hold the arcade stick and pry the back panel away from the device until it comes off.
Locate the back piece of the joystick.
Remove the four screws that secure the joystick using the Phillips #0 screwdriver.
Use a flathead screwdriver to remove the middle screw that holds the ball piece onto the joystick.
Remove the ball piece and set it aside.
Locate the joystick wires that are attached to the four plugs on the motherboard and disconnect them.
Remove the back piece from the mounting plate.
Replace the joystick's back piece.
Één andere persoon heeft deze handleiding voltooid.
