Deze vertaling is door een computer gegenereerd en is nog niet door iemand nagekeken. Spreek je deze taal? Bekijk het hier.
Inleiding
Zeer eenvoudige instructies om de controller te openen
Wat je nodig hebt
Verwijder het kapje van beide triggers door er met je duimen op te duwen.
verwijder de batterij
Zoek de vier schroeven
Twee bevinden zich aan het uiteinde van de handvatten
Twee worden verborgen door het label achter de accu
Verwijder de vier T6 Torx-schroeven
Maak beide kanten voorzichtig los. Dit is vrij eenvoudig en vereist geen extra gereedschap.
Scheid de twee kanten en let daarbij op de flexkabel.
Volg deze instructies in omgekeerde volgorde om je apparaat weer in elkaar te zetten.
14 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
It was an okey guide but the description of how to open the clips after unscrewing was very vague and I had no clue there these clips where and when open I notice three clips. One in between the joysticks and two underneath L & R buttons. Also I needed a flat screwdriver to open them up.
This guide is accurate and also works with the Pro 2 controller by 8BitDo. I would add that, as a previous commenter has mentioned, the location of the clips is unclear. I found that once the screws were removed, there was little resistance when seperating the two halves of the shell when starting from the 'bottom' of the controller (along the thighs/between the joysticks and in front of the player number LEDs). The 'top' of the controller, where the shoulder buttons are, was slightly trickier, and with the Pro 2 at least, it is necessary to pop the L2 and R2 buttons out of the claw hinges to fully separate the two halves of the shell.
Once the halves are separated, you may not have to remove the ribbon cable depending on the repair you are doing. It is located between the thumbstick on the Pro2. It is a shorter cable, so for a simple job like replacing the sticks (as in my case), it might be worth it to take a bit more careful so you don't spend more time reattaching it than doing the actual repair.
