Ga door naar hoofdinhoud
8BitDo SN30 Pro+ Controller Triggers Replacement
Wat je nodig hebt
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: stap 1, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: stap 1, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: stap 1, afbeelding 3 van 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    Vraag FixBot
    Voeg opmerking toe
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: stap 2, afbeelding 1 van 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: stap 2, afbeelding 2 van 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    Vraag FixBot
    Voeg opmerking toe
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: stap 3, afbeelding 1 van 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    Vraag FixBot
    Voeg opmerking toe
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: stap 4, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: stap 4, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: stap 4, afbeelding 3 van 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    Vraag FixBot
    Voeg opmerking toe
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: stap 5, afbeelding 1 van 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: stap 6, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: stap 6, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: stap 6, afbeelding 3 van 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    Vraag FixBot
    Voeg opmerking toe
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: stap 7, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: stap 7, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: stap 7, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
    Vraag FixBot
    Voeg opmerking toe
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: stap 8, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: stap 8, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: stap 8, afbeelding 3 van 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
    Vraag FixBot
    Voeg opmerking toe
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: stap 9, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: stap 9, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: stap 9, afbeelding 3 van 3
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
    Vraag FixBot
    Voeg opmerking toe
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: stap 10, afbeelding 1 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: stap 10, afbeelding 2 van 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: stap 10, afbeelding 3 van 3
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brian W
1.800 Reputatie
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 91
Altijd: 4,819
