Wat je nodig hebt
Place the tablet on its side so that the two screws are facing upward.
Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
Repeat this step on right side of charging port.
