Ga door naar hoofdinhoud
360fly 4K Lens Replacement
Wat je nodig hebt
  1. 360fly 4K Lens Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
    In the older model for Fly360 camera, the screws are PH000.
    Renjamin - Antwoord
    In the old 360Fly HD camera, the screw requires a #00 Philips head screwdriver. Unfortunately for me, one of the screws on mine was torqued down a bit too tight, that I ended up stripping the screw head trying to loosen it by hand.
    XzTS - Antwoord
  3. 360fly 4K Lens Replacement: stap 3, afbeelding 1 van 2 360fly 4K Lens Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Lens Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Lens Replacement: stap 5, afbeelding 1 van 2 360fly 4K Lens Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Lens Replacement: stap 6, afbeelding 1 van 3 360fly 4K Lens Replacement: stap 6, afbeelding 2 van 3 360fly 4K Lens Replacement: stap 6, afbeelding 3 van 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Do I have to remove the battery to replace the SD card?
    BoB - Antwoord
  7. 360fly 4K Lens Replacement, SD Card: stap 7, afbeelding 1 van 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K Lens Replacement: stap 8, afbeelding 1 van 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K Lens Replacement: stap 9, afbeelding 1 van 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K Lens Replacement: stap 10, afbeelding 1 van 1
    • Press and release the SD card to remove it from the circuit assembly.
    Does anyone know how large a card the 360fly can support? I’d like to put a 256gb card in if it will support it.
    BoB - Antwoord
  11. 360fly 4K Lens Replacement, Lens: stap 11, afbeelding 1 van 1
    • Unscrew the five 3mm screws with a T4 screwdriver.
  12. 360fly 4K Lens Replacement: stap 12, afbeelding 1 van 1
    • Gently push against the lens module to remove it from the 360fly 4K assembly.
    Boa Tarde...  Resido no Brasil a lente da minha FLY 360 4k Foi danificada onde consigo uma lente de reposição ?
    thiagoboesingg - Antwoord
Conclusie
Jacob Herron
463 Reputatie
3 handleidingen geschreven
IUPUI, Team S5-G3, Baechle Fall 2017 Lid van IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Leden
4Gids Commentaar
Hi. Where to get a replacement lens as I am in need for this repair, but 360fly offer a full service for $150 and do not sell spare lenses. Thx
anguel nakov - Antwoord
There is no info where to buy the replacement lens.
gelo3000 - Antwoord
Anyone know about usb pinout? I lost my charger adapter
Nuri Can PEHLİVAN - Antwoord
Hi.
I inadvertently found your question.
I have this same problem.
I've lost the charger, too, and now I'm looking for a chance to charge without a base, or a chance to buy a base.
Imants
Imants R -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,695
