Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
2013-2017 Ford Escape Key Fob Battery Replacement
Wat je nodig hebt
  1. 2013-2017 Ford Escape Key Fob Battery  Replacement, 2013-2017 Ford Escape Key Fob Battery: stap 1, afbeelding 1 van 1
    • Slide over the key release switch on the back of the fob.
  2. 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 2, afbeelding 1 van 1
    • Remove the metal ignition key from the fob.
    Push the button against the spring and use a fingernail to pry out the key.
    Dan Smith - Antwoord
  3. 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 3, afbeelding 1 van 1
    • Insert the ignition key in the notch on the left with the FORD logo facing upward.
    It works better if the end of the key is placed under the square protrusion in the center area next to the hole for the key. Use the key to gently, but firmly, lever the protrusion away from the main case. You will feel it 'pop' as the back cover comes away.
  4. 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 4, afbeelding 1 van 2 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 4, afbeelding 2 van 2
    • Gently remove the back cover of the key fob.
    (See comment above.)
  5. 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 5, afbeelding 1 van 2 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 5, afbeelding 2 van 2
    • Remove the old battery using the ignition key.
    I cannot get the back cover off
    Kitty Wolf - Antwoord
    See my new comment above.
    Dan Smith -
    The key is too clunky to fit next to the battery to pry it out. Use the tip of a pocket knife blade or a pointed plastic spudger to get down into the pocket next the the battery and pry it out. Remember, the '+' side of a new, 2032 battery faces "down" into the case.
  6. 2013-2017 Ford Escape Key Fob Battery  Replacement: stap 6, afbeelding 1 van 1
    • Insert the new battery with “+” facing downward and the “-“ facing upward.
    I like to write the current date on the battery with a Sharpie marker, so I know how long they last.
    Place the narrower end on first and 'walk' the cover sides back into the groove, moving back toward the pushbutton end.
Conclusie
To reassemble your device, replace the back cover to the key fob and secure firmly.
36 andere personen hebben deze handleiding voltooid.
16 opmerkingen
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - Antwoord
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - Antwoord
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - Antwoord
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - Antwoord
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Joseph Kuperberg - Antwoord
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Scott - Antwoord
super easy. Clear simple guide. Took me less than a minute!
dobos_b51 - Antwoord
That was easy! Thank you for the pictures and the easy to follow instructions!!
rocky752 - Antwoord
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
Tiffany Nelson - Antwoord
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
Cathy Hawn - Antwoord
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Mark - Antwoord
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Paula Haenchen - Antwoord
Easy Peasy, Thank you!
Leslie Gaynor - Antwoord
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
lindasscott1 - Antwoord
Did all this and does not restart at all lights don’t go on and trunk don’t open
Vicenta - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 193
Afgelopen 30 dagen: 931
Altijd: 169,324
