Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gereedschap
Onderdelen
  1. Deze stap is niet vertaald. Help het te vertalen
    Slide over the key release switch on the back of the fob.
    • Slide over the key release switch on the back of the fob.
  2. Deze stap is niet vertaald. Help het te vertalen
    Remove the metal ignition key from the fob.
    • Remove the metal ignition key from the fob.
  3. Deze stap is niet vertaald. Help het te vertalen
    Insert the ignition key in the notch on the left with the FORD logo facing upward.
    • Insert the ignition key in the notch on the left with the FORD logo facing upward.
  4. Deze stap is niet vertaald. Help het te vertalen
    Gently remove the back cover of the key fob. Gently remove the back cover of the key fob.
    • Gently remove the back cover of the key fob.
  5. Deze stap is niet vertaald. Help het te vertalen
    Remove the old battery using the ignition key. Remove the old battery using the ignition key.
    • Remove the old battery using the ignition key.
  6. Deze stap is niet vertaald. Help het te vertalen
    Insert the new battery with “+” facing downward and the “-“ facing upward.
    • Insert the new battery with “+” facing downward and the “-“ facing upward.
Eindstreep
30 andere personen hebben deze handleiding voltooid.
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - Antwoord
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - Antwoord
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - Antwoord
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 44
Afgelopen 7 dagen: 306
Afgelopen 30 dagen: 1,417
Altijd: 123,707
