Inleiding
Here is a straight forward bulb replacement. Only requires the simplest of tools and is a quick fix.
Wat je nodig hebt
Here is a 2000 Jeep Grand Cherokee with a burned out driver side headlight bulb.
Open the hood. On top of the affected headlight assembly is a single 7mm hex bolt.
Remove the bolt
Use a flathead screwdriver (or similar tool) to lift the socket clip of the tab on the bulb and remove the bulb.
Change the bulb and the result will be fully functional headlights.
What if the hex bolts won't come out? I think someone got to them before me and stripped them.
To reassemble your headlight, follow these instructions in reverse order.
18 andere personen hebben deze handleiding voltooid.
11 opmerkingen
guide made this an ABC REPLACEMENT
Easy peasy. Thanks!
On my 2001 Jeep Grand Cherokee Limited, there was an extra screw that needed to be removed. I didn't notice it and, in trying to remove the headlight housing, broke the plastic housing that was held in place by that screw.
You didn't notice it? I wouldn't have you working on my car if you're that careless.
FixIt -
Justin answer the question we don't want to hear rude comments just the answer geeh dude so abrasive to ppl. C wats up wit that
@fixitorlistit there is no reason to be like that! You do not know who your audience is and there is nothing wrong with breaking things while trying to fix things. I suppose you never had a mishap fixing things and never broken anything.
Stop being rude an just answer the question we didn't ask to be put down but we need information every body ain't savy on vehicle repairs don't be doing that telling ppl what u wudnt let them work on we didn't ask that. Ok
So true I feel the same way about the way you put it
You said that beautifully than he needed it
What kind ( name) is the bulb socket 2002 model is it h7 h4 or hb4/9006 I want to put zener gas bulb thanks Boetie
