Back Panel
10 Antwoorden 10 Score |
My Keypad doesnt work it got wet .How do I fix it? |
4 Antwoorden 81 Score |
How to fix application error 523? |
9 Antwoorden 5 Score |
screen has frozen on start up |
2 Antwoorden 2 Score |
doesnt charge, the part where the charger connects inside has broken |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
The BlackBerry Curve 8520 belongs to the 8500 series of mid-end consumer oriented smart phones. The 8520 is well equipped with WiFi, Bluetooth connectivity and a 2 megapixel camera. Attributes particular to the 8520 are its support of GSM/GPRS/EDGE networks and its 17 days of standby potential.
The BlackBerry 8520 should not be confused with other smart phones of the 8500 family, particularly the Blackberry 8530; both the 8520 and 8530 have the same physical build.
Identification
To ensure that you are working with a 8520 phone, check the label reading "BlackBerry 8520" under its battery pack.
