Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Trackpad replacement without keyboard replacement
Can the trackpad be replaced without replacing the keyboard? I have a broken trackpad and can't seem to find a part number for it. My mac is a MacBook Unibody Model A1278.
Thank You
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Yes it can! Your part number is 922-9014. You will, however, need a tri-wing screw driver to replace it. Plugging that part number into Google will lead you to the part.
Good luck!
Was dit antwoord nuttig?
Score 5
Thank You for responding my post. I found the part using the part number you provided.
1 Opmerking:
Great! I'm glad you found what you needed!
door
I have a late 2008 model Macbook 5,1 aluminum case version. Is this a A-1278? I have a defective trackpad on the unit and need a replacement. Is the part number 922-9014 correct? Thanks, Knut Holzer
Have the same question as above: also have a late 2008 model MacBook 5,1.
Same here. Would love to know.
1 Opmerking:
These old questions rarely get looked at. Asking a new question brings better results and new things may have been learned in the last year and half.
door
http://www.everymac.com/ultimate-mac-loo...
Yes, they are all the same machine.
Voeg je antwoord toe
avelez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 10,747
