Ga door naar hoofdinhoud
iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Is dit een goede vraag?
Score 1
1 Opmerking
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
Was dit antwoord nuttig?
2 opmerkingen:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
door
I can see you!
door
Voeg je antwoord toe
Ben Eisenman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,530
