Ga door naar hoofdinhoud
Vraag afgerond
i3 iMac Screen Dips Downwards
Hi,
Problem with my iMac i3
The screen keeps sagging downwards, hard to explain however, normally if you press the screen at the top it leans upwards and you can adjust it to a suitable level, however my keeps sagging right down so it's almost pointing towards the desk
any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I'd be talking with Apple - there have been some "known issues" with iMac stands. However the stand has to be unlatched with a key card then adjusted and re-latched in the proper position, and, as you can see some have resorted to replacing the VESA mount.
If this answer was helpful please remember to return an mark it Accepted.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 689
