How to turn on monitor
Is dit een goede vraag?
Hi,
First check that the monitor is plugged into a power source. Check that the cord is plugged in all of the way.
Locate the power button (it’s either a physical button or a touch sensitive icon located on the bottom right edge of the monitor bezel. Press it once to turn the monitor on. You should see an LED indicator light on the monitor change or turn off/on depending on its active state.
If the LED light is blinking, the monitor is in sleep mode. Move your mouse or press a key on your keyboard to wake it up.
If you have a message that says "Check Signal Cable," your monitor is receiving power, but needs an active input from your computer.
Hope this Helps!
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 30
Altijd: 30
