Powers on only after sitting without power
Hi! I've got several 12" iBook 600MHZ laptops which power on once after sitting for a period of time disconnected from power. Then, if you shut them off or pull the power, they will not power on again until you let them sit for a while, disconnected from power. It is as if they are shorting out and needing to discharge. The DC-ins are good, and I've tried replacing them to no avail. I've removed/swapped memory, reset the PMU/PRAM, etc. It's not the G3 video issue.
Anyone have an idea what is causing this behavior?
Is dit een goede vraag?
