Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Where to replace stripped MacBook 2012 screw?
Believe it or not... I've already stripped a screw trying to remove the bottom of my 13" MacBook Pro (mid-2012). I'm going to buy the Moody's extractors I've seen mentioned on here, but where can I get replacement screws?
I only need one of the longer screw length. I'm open to buying a full set, though, seeing as I still have to remove the case without stripping any additional screws.
Thanks for the help!
-Brian
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is the DIY volunteer forum, not iFixit Customer Support. They can tell you if 2011 screws will work, if they have them and if they'll sell you less than a set. You may as well order the special tools required as every job is easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Brian Sharon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 947
