Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
428 Vragen Bekijk alle
Why Does my ps3 go green -> yellow to red blinking light?
My ps3 will power on but a split second later go to yellow then 3 beeps with red blinking light. Is this the ylod issue that ps3 phat had? I have the tools needed to fix yold if that is it but i want to confirm thats the issue. The system is about 3 to 4 years old
Is dit een goede vraag?
Score 10
3 opmerkingen
I have same issue. change thermal paste, heat gun to motherboard before paste and no luck
door
Its the ylod my friend and ifixit DONT have a solution for the PS3 slim!!! I have it as well and iam annoyed that they dont have a solution for THE SLIM!! (The YLOD is the YELLOW LIGHT OF DEATH!!! :(...)
door
I'm having the same problem with a slim and it is not the YLOD. I have reflowed it twice and have yet to find a solution on this site or youtube. Please keep any new information on this problem with the slims available by posting, Thanks
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
This sounds like the early stages of a YLOD. I would advise you to open up your ps3 and clean it from any dust. Also see if the thermal paste has dried out. If so, replace it.
Source: http://vkrepair.com/ps3-flashing-red-lig...
Was dit antwoord nuttig?
Score 6
http://www.youtube.com/watch?v=uMG-6rban...
I have worked on PS3's for years the Yellow light is the GPU. You need to reball the GPU to really fix it right. You can reflow the GPU, but it want last.
1 Opmerking:
I've had to fix YLOD on my old ps3 a couple of times with my dad. Look up how to Reflow your motherboard. It's usually a temp fix, but it can get it working for a couple of months before you need to do it again.
door
It is probably an older model PS3, the big one. A lot of them have the same symptom of YLOD. Today it is known that probably capacitors are the problem. The rectangular black things on the bottom of CPU and GPU. You can try to replace them with other more reliable and see if it works! I see question is old and if you want information about what type of capacitors and how to do it feel free to ask for more information.
3 opmerkingen:
gUru0026 could you provide more info on the the types of capacitors and how to replace them?
door
Its for the older PS3 model
door
its confirmed to be the gpu die separating from the substrate in most cases, replacing the tonkin capacitors may temp fix it, but only as a coincidental thing.
to find out exactly, there's a serial communications method called syscon. it involves soldering wires to test points on the motherboard and hooking it to a usb uart dongle to read the error messages directly from the boards log files via commands sent to the uart device.
door
Voeg je antwoord toe
Louis Royal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 191
Altijd: 19,188
