Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Home botton can rotate 360 degrees
After my hubby replaced my cracked screen all was well Intill I noticed the home botton is kinda loose and can spin. Is also not as responsive as before. He opened the phone up again but couldn't figure it out. Any help would be greatly appreciated!
Thanks kindly
Jessica
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It sounds like the rubber gasket in the home was removed when he fixed the cracked screen. If this is the case, you can purchase a new home button here and it's fairly in-expensive. It's also easy to put back in the phone. I hope this helps.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jess zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 4,956
