Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
20 Vragen Bekijk alle
bottom half of touch screen not working after replacement
swapped out the digitizer and now the bottom icons do not work
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It sounds like either a faulty digitizer or maybe something might have gotten unplugged when you put it back together. I would try to pull it back apart and make sure that everything is connected properly and if you still have an issue, then I would say that it is a faulty digitizer.
Was dit antwoord nuttig?
Score 1
Do as Michael Stoffer writes, but also make sure contacts are clean and nothing is in the connector port.
Score 1
Voeg je antwoord toe
sheldon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,488
