Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Replacemnt home button sticks after replacement.
I recently installed new housing on my 4S and now I have to press the home button pretty hard for it to make contact. The home button was a yellow after market one. What could I have done wrong when installing to cause this?
Is dit een goede vraag?
1 Opmerking
No it wasnt, and i thought that may be the issue. Does the metal piece come off easily?
Thanks for your help!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
was there a little metal square on the back of ur home button with ur new conversion kit?if not take the little metal spacer off the back of ur other home button that should work.
Update
yes it comes off easily its just stuck on with a bit of adhesive should be no problem to remove
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 897
