Ga door naar hoofdinhoud
De zevende iteratie van de iPod Touch van Apple, uitgebracht in mei 2019. Dit model wordt geleverd met maximaal 256 GB opslag en een A10-processor. Modelnummer A2178.
Can't remove the front display!
It seems impossible to remove the front display! I used the iOpener repeatedly, a heat gun, all to no avail. I bought a new display and all the tools to replace it, but I can't get started. The adhesive just doesn't want to budge! Help!
Is dit een goede vraag?
Score 1
2 opmerkingen:
OK I got it open now. It took 3-4 days of working t it. Hint to others: The display started to separate slightly on the side, at about 3/4 " above the bottom. I was able to get a razor blade between the display and the frame and slid it down to the bottom, then pulling it across the borttom cutting the adhesive. Now it is on to the rest of the work! DBS
door
@davidswans58182 Congratulations!
door
Voeg een opmerking toe
1 Antwoord
If the front display won't come off, don't force it. Double-check that all screws and ribbon cable connectors have been removed or disconnected. The display may still be held by adhesive clips—apply gentle heat around the edges and use a plastic opening tool to carefully separate it. Forcing it can crack the screen or damage the frame.
Was dit antwoord nuttig?
Voeg je antwoord toe
David Swanson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 185
