Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Meta Quest 3S mixed reality-headset werd uitgebracht op 15 oktober 2024 en is het jongere en kleinere broertje van de Meta Quest 3.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
Was dit antwoord nuttig?
I was just playing vr but end then i didint know that it was the last time to play vr so the tracking device is broken and i do not know how to fix it will you help me
Voeg je antwoord toe
Kai Bannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 142
Altijd: 712
