Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Vragen Bekijk alle
Problem after memory upgrade
I recently purchased the following memory upgrade from Apple:
MD019G/A Apple Memory Module 8GB 1333MHz DDR3 (PC3-10600) - 2x4GB
For my MBP (Early 2011) 2.0Ghz
Installation went fine. The system booted ok. Everything seemed fine, when I looked at my system information it showed that the 8GB of RAM were running at 1333Mhz. Then I rebooted my MBP and started Apple Hardware Test. First test passed fine, but during the 2nd test I got this error: "4MEM/64/40000000 0x84486198". Then I turned off power, when i turned it on again, I've got a black screen with 3 beeps and 3 front led flashes. I tried to swap memory modules with no success. When I inserted the original memory back system booted up as usual without any problems. After that I reseted PRAM and NVRAM, reinstalled the new memory and I got 3 beeps again. Any suggestions please?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You have bad ram. The 3 beeps signifies that there is defective ram in your unit. You should contact Apple and ask for a replacement or a refund and then buy ram from another store like OWC or Crucial because they are much cheeper and have never come defective when I ordered them.
Hope this Helps
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thank you for the answer. I still can't belive that $200 "guaranteed to be compatible with your Macintosh" Apple memory is crap. I thought for this price it could be well tested. By the way, the faulty memory is Hynyx branded. On Monday I am going to call Apple and ask for replacement.
door
That is why I only buy memory from OWC or Crucial. It is roughly half the price and has never disappointed me.
door
Today I received the memory replacement. Everything seems to be fine.
door
Voeg je antwoord toe
aein aeinner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,771
