Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
6 mths after replacing battery, phone turns off @ 50-60% batt.
I purchased a replacement 3GS battery from iFixit last fall and installed it during the winter. The phone itself is ~2.5 years old.
The battery life has seemed to degrade considerably faster than the original OEM battery. I try to maintain battery health with a discharge to ~15% and then fully recharge it at least once per month.
Over the past few days, the phone has consistently turned itself off during normal use while still reading as having greater than 50% battery life remaining.
Has anyone else seen similar issues with replacement batteries? If so, should I seek another replacement?
Thank you!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This happens to a lot of aftermarket batteries. Best bet is to just pick up another one and swap it out.
Was dit antwoord nuttig?
Score 1
I have also bought an IPhone 32gs battery (APN 616-0434) form IFIXIT on May 05 2012 and after almost 4 month (September 1 2012) the phone could not power on nor recharge any more.
I replaced the new battery with the old (original one) that was defective and the IPhone started to recharge again. The problem with the original battery that is now installed in my IPhone is that it could not keep the charge. It went form 100% to Zero in seconds…. Now, I will only be able to make a call while the phone is connected to an external battery… until I get a new Battery.
But 4 Months is really very fast to a battery life. I would expected a year…
Regards
Marcelo
Voeg je antwoord toe
cnewport zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,433
