Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
Is dit een goede vraag?
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
Was dit antwoord nuttig?
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 78
Altijd: 487
