Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Vragen Bekijk alle
LCD panel removable from the shell?
Do you know if the actual LCD panel is removable from the top case, or is it glued inside like the MacBook Air?
It seems to me like a hybrid between the heat-gun approach from the Unibody MacBook Pro and the don't-go-there-unless-it's-broken separation of LCD and backlight that comes from the Air. What do you think?
I'm gonna buy one tomorrow and will try to find out.. Any pointers on how to do so without ruining this hyper-expensive screen?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Nope, glued.
Also it includes a crapton of other stuff that's all right in with it.
Was dit antwoord nuttig?
3 opmerkingen:
Ps, how do you know about the crapton? :)
door
It's all in the teardown I linked in my answer.
door
Oof.. Did you succeed in removing it without breaking the LCD?
door
Voeg je antwoord toe
victormilton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 983
