Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
battery replacement instructions / guide
I need to replace the battery on my ipod touch 4th generation.I understand that the battery is available from Ifixit.
Do I get the replacement instructions with my order?Or can I find disassembly instructions online please.
Any link to the disssembly guide is higly appreciated.
thanks
vahid
Is dit een goede vraag?
Score -1
4 opmerkingen
Thank you for your reply.
Do I need to use new adhesive once I have change the battery?
door
No, you will not. Just align the battery so that the ribbon cable is straight.
door
So ,after I have changed the battery , I'll just put everything back togeter and no new adhesive.The existing adhesive will work again no heating required.right?
door
No, you will need either new adhesive or some super glue.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This will provide you with the guide to tear down the iPod until you get to the battery: iPod Touch 4th Generation Headphone Jack Replacement
Unfortunately, they do not have a direct guide to replace the Battery, this specific one is for replacing the Headphone Jack.
Best of Luck,
Was dit antwoord nuttig?
Voeg je antwoord toe
Vahid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 697
