Ga door naar hoofdinhoud
The Chevrolet Blazer (4WD model T-10) and its rebadged variant, the GMC S-15 Jimmy (4WD model T-15), are compact/mid-size SUVs manufactured and marketed by Chevrolet and GMC from 1982-2005 across two generations.
Engine stall and rough idle after cap and rotors replacement
Cap and rotor replace and tune
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
My most infamous repair blunder came when I had similar symptoms after a cap and rotor replacement.
After a couple of days troubleshooting, I finally realized I had switched two of the spark plug wires. Once I finished banging my head on the worktable, I swapped them back and everything was fine.
So get yourself a cylinder diagram and the firing order and triple check the plug wires go to the right plug.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Jerry....I thought about that but haven't done anything from banging my head too lol.... I'll definitely check it though.... thanks again man!
door
Voeg je antwoord toe
Lowride92 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 41
