Ga door naar hoofdinhoud
The dual SIM version of Nokia's C2 series, released in 2011.
9 Vragen Bekijk alle
Restart often due lose the signal
Always my mobile Nokia C2-06 dual SIM lose a signal of one or both SIM card due bad signal because I am in a hidden places I have to switch it off and on again to stablish the signal again.
Do you know why? Is there some solution to fix this problem?
Thanks in advance,
Geanderson
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No, There isn't any solution because it is not a problem. it's common. as you mentioned you'r living where signals are weak. (hidden places)
so when you power it on. it detects it because it was by its full potential. but once it is on. potential goes weak.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Geanderson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,656
