Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
431 Vragen Bekijk alle
Memory Slot Not Working
A while ago I upgraded my iMac EMC 2134 to 4 gb and all worked fine until one day when I switched it on there was only a black screen. Power was getting to the computer and I could hear the DVD drive start to work. I tried everything I could think of to get it to start even removing the new memory and replacing it with the hold. Nothing worked until I started the computer having forgot to put the memory in slot 0. As soon as any memory was placed in that slot the computer refused to boot. Has anyone else come across this problem and is there an easy solution to fixing it
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try cleaning the slot with contact cleaner and a toothbrush. If it still won't start swap the memory and try again. If it still won't work you will have to decide whether to live without one memory slot or replacing the system board. Good luck Ralph
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Graham J zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,104
