Ga door naar hoofdinhoud
iRobot Roomba 5xx Series Battery Replacement
I want to replace the battery pack on an iRobot Roomba 500 series. How do I gain access to the battery pack already installed in the Roomba? I have seen photos of a battery pack purchased from batteryspace.com intended for the Roomba, but not photos showing how to access the battery compartment itself. Thanks, Bob Cochran
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I've got the URL for the manual for the Roomba for you. Scan down and you will find info on removing and replacing the battery. Ralph
http://www.irobot.com/uk/home_robots_faq...
Was dit antwoord nuttig?
Score 2
Hi, before you go and buy a replacement battery, you might want to try to reset the Roomba first. The Roomba may be set in a state where it will only charge to a certain amount. Just follow the instructions indicated here to reset your Roomba.
http://www.eesolutions.ca/roomba_battery...
Score 2
Voeg je antwoord toe
cochranb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 8,243
