Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Battery cable connector unstuck, any ideas?
hello, i tried to open up my iphone 4s to install the lighting mod from kogadget. the first step was to disconnect the battery cable, but i accidentally unstuck the whole connector. now the phone turns on, but it doesnt charge (the battery icon changes to that "battery plug"). is there anything i can do to repair this?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I repaired a guy's phone who had the same problem. The only thing you can really do, unless you are good with soldering, is to make sure the prongs on the connector are touching the silver solder marks on the logic board.
His broke off too and I was able to get it working again by setting the connector properly on the logic board.
Was dit antwoord nuttig?
3 opmerkingen:
thanks mate, but there is a problem with the terminal now. one of the pads is damaged, and i am not very experienced with electronics. i tried attaching a copper wire from the terminal to the connector with no luck.
door
If that is the case the next step is to have it resoldered. Not much else you can do at that point. Sorry friend.
door
yea it seems so. thanks anyway.
door
Voeg je antwoord toe
Pangratios zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 418
