Won't stay on with loud noise.
Okay, so we just moved. Amana dryer was fine at old house. Move here, loud grinding noise and won't stay on past 10 seconds.
Replaced all of the parts. Same problem. Bought a new dryer, same problem! Loud grinding noise then shuts off.
Replaced the wiring from the breaker that is less than 3 years old, to the outlet, new outlet head. Everything is BRAND NEW and the dryer won't stop making the noise and won't stay on.
Is dit een goede vraag?
3 opmerkingen
Hi @hannabasler
What is the model number of the new dryer?
Have you checked that the wiring is OK in that the correct voltage and earth appears on the correct wires at the machine?
Does it need one breaker or two breakers i.e. two separate power feeds (1 x 120V AC or 2 x 120V AC), to operate?
Is there also a GFCI or RCD connected in the dryer's power supply at the house power box?
door jayeff
Model number HTX26EASW0WW
I honestly am unsure of the rest.
I see on the dryer it says
120/240v 60 hz 24a 3 wires
120/200v 60 hz 440w 22a 3 wires
Im new at this DIY stuff
door Hanna Basler
Thank you so much!
door Hanna Basler
