Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
861 Vragen Bekijk alle
MacBook Pro doesn´t turn on but charges the battery
Hello
i have a Macbook Pro Mid 2009 13" and the problem is that it wont turn on. When i press the Power button nothing happens, its dead. But the battery charges and the LED on the left side shows the battery status.
Can you please help me?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Have you spilled anything on it?
door
No i didnt spill anything on it.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
4 Antwoorden
Gekozen oplossing
Your power button could be non functional. You could remove the bottom panel, disconnect the top case ribbon cable from the logic board then trigger the two power pads on the logic board to power up the machine. If the machine starts up then you know your top case is in trouble.
Was dit antwoord nuttig?
Score 3
Commentaar:
I'm assuming by top case ribbon, you mean the one on the top right after opening the bottom panel, with battery close to you. But where are the 2 per pads on the logic board to power up the machine?
door
Question, does this fix the button or merely turn on the macbook ?
door
this might help
http://support.apple.com/kb/TS1367
Score 2
Commentaar:
Tried to reset but it didn't work. The light of the power cable didn't change.
What else can i try?
door
Move your Moniter in different angles while pressing the power button
door
It doesn't help because nothing happens when I press the power button, no fan noise, nothing
door
try one of these solutions
http://youtu.be/Igspc4eymuQ
I have a problem that my mac doesnt turn on and the battery shows the signe that ok and it charged normaly but when i press to turn on he make like when noise and exactly iheart it coming from the hitachi how you could help me please?
Voeg je antwoord toe
Fuad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 45
Afgelopen 30 Dagen: 204
Altijd: 33,790
