Ga door naar hoofdinhoud
The DeWalt DWD450 is a corded 1/2" 11 amp right angle drill.
How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
door
@tony20811 How many wires go to the switch?
door
Voeg je antwoord toe
Matt Littlejohn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 74
