Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
How to clean speaker
Is dit een goede vraag?
Score 12
Voeg een opmerking toe
8 Antwoorden
Filteren op:
Het nuttigste antwoord
This generally works if the speaker sound is very low but you can hear it. If you can't hear anything then you might need a speaker replacement but it wouldn't hurt to check to see if its cleaned.
The way I clean phone speakers is with a toothbrush, isopropyl 99% alcohol and compressed air.
  1. Look at speaker to see if you can see anything blocking it
  2. Take dry toothbrush and brush the speakers using a little pressure but not much (you may see stuff come out keep going for like a minute)
  3. Puff the speaker area lightly with some compressed air
  4. Test call to see if sound improved
  5. If not, Put a couple drops of isopropyl alcohol on to toothbrush and complete step 2 and 3 again.
  6. Test call to see if sound improved
  7. If not, put could of drops of isopropyl alcohol into speaker area and plus a medium stream of air into speaker area not to powerful, then follow up with one minute of brushing.
  8. Test call to see id sound has improved
  9. If following this doesn'twork then more than likely you need a speaker replacement.
Was dit antwoord nuttig?
Score 1
Spker cleen this
Score 1
Ho my best wishes
Score 1
In my realme phone mic can't work properly when I was calling with another one voice can't hear and not going to another person
Score 1
1 Opmerking:
لا يعمل الميكرفون بشكل صحيح ولا استطيع سماع الطرف الاخر
door Deel
Its not working proper sound of my phone
How to clean the speaker
Realme narzo 60 display repair
How I can clean my phone speaker
Voeg je antwoord toe
Girraj Goyal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 84
Altijd: 5,636
