Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Vraag afgerond
MacBook Pro display not working, no backlight. what to do? please help
Hi, well my girlfriend spilled water on her macbook in her bag and i told her not to try to turn it on. after a few days i tried it and it would power up as soon as i would connect the charger. Everything seems to be fine but there is no display on the screen. i could see a display with a torch but the backlight doesn't turn on. Also the power button and some keyboard buttons don't work and i hear a beep wen i press some of them.
i opened it up and cleaned almost everything with 99.8% isopropyl alcohol. i also soaked the logic board for a bit more than an hour and then cleaned it with a toothbrush. there wasnt much corrosion on it in the first place but it looks almost new after the cleaning. i then put it back together and the same problems are occuring. is there anyway to find out if there is a problem with the logic board or if the screen is damaged? i could replace the keyboard if it doesnt work but i cant seem to figure out what happened to the screen.
Any help or suggestions would be greatly appreciated
Is dit een goede vraag?
2 opmerkingen:
Would you give us the last three figures of your serial number so we know your exact machine. Thanks
door
the last three figures are H2G. It is a late 2011 unibody and the model number is A1278. Thanks
door
Voeg een opmerking toe
1 Antwoord
There is no simple fix for this you will need to send it in to a professional repair shop that can test the logicboard and fix the bad circuits.
unlike the older non-unibody macbooks you could easily replace the inverter which provides power to the backlight on the LCD.
the unibodies inverter/lcd power is built onto the logicboard now days.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 4,901
